220
Custom Sort Order with IEnumerable
Hello, first post here.
Edit: "
The following code I'd like to use to sort one of my columns:
        Char[] myArr = new Char[1] { 'A', '!', 'B', 'C', '$' };
        IEnumerable<char> yourOriginalValues;
        yourOriginalValues = myArr;
        IEnumerable<char> result =
               yourOriginalValues.Where(c => Char.IsLetterOrDigit(c))
                    .OrderBy(c => c)
                    .Concat(yourOriginalValues.Where(c => !Char.IsLetterOrDigit(c)));
So far I have
        private void ultraGridDaySheet_InitializeLayout(object sender, InitializeLayoutEventArgs e)
            e.Layout.Override.HeaderClickAction = HeaderClickAction.ExternalSortMulti;
  • 469350
    If you want to sort a column in a custom order, then the thing to do it implement the IComparer interface and then set the SortComparer property on the column to an instance of the implementor.
    If you do a search on these forums for "IComparer" or "SortComparer", I'm sure you'll find a whole bunch of sample code.
    • 220
      posted in reply to Mike Saltzman
      Quick question, when I'm returning the value of:
      int IComparer.Compare(object x, object y)
      Is it returning the position for the string?
      • 17259
        Offline posted in reply to Wesley
        No. You need to return any number bigger than zero if x > y, or any number below zero if y > x, or zero if they are equal.
