Connecting the XamPivotGrid/XamPivotDataSelector to an ssas server in tab mode, i can see my Measures/Hierarchies, but no Levels beneath the Hierarchies.
Connecting to the same server with Excel works like a charm. Doesn't the xamPivotGrid support Tabularmode?
BR,
Daniel Clausen
Note that I can successfully connect to this Tabular Model from Excel, from this same PC, using Power Pivot.
If you want to know more about SSAS, you can ask me.
Thanks & Regards,
Anita
Hello Jeferson,
As Rob mentioned we have logged this behavior with our engineering staff to look into the issue further. I have created a private case for you to track progress of this issue. Your case number is CAS-119135-L1H5T8. I will be contacting you thru this case in regards to this issue.
Sincerely,
Valerie
Developer Support Engineer
www.infragistics.com/support
Dear sir,
I have the same problem appointed by Daniel.
I created a tabular cube instance and I'd like to know if this issue (CAS-115581-L7S3S1) was solved and how can I solved this problem.
I have a urgent project to deliver and this solution is very important to me.
Best regards,
Jeferson Rodrigues
Brazil, Sao Paulo - SP
Daniel, caso tenha acesso à essa solicitação eu gostaria muito de saber se resolveu esta questão e qual o caminho encontrado para solucioná-la.
Seu contato seria muito bem vindo!
Atenciosamente.
(011) 99119-2855
jeferson.rodrigues@linx.com.br
Hi Daniel,
If the data shows up properly in excel I would expect that it functions the same way in the xamPivotGrid. It's not a requirement to have an "All" node in the hierarchy.
Initially I thought you were referring to the hierarchies in the data selector not showing up but as I tested the issue more I found that when I dragged a dimension to the row or column section that the rows did not fill in and I was presenter with a screen similar to your initial screenshot where you have "ArabicDescription" in the columns section but there are no columns appearing.
I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 144176. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I have also created a private case for you on this issue (CAS-115581-L7S3S1) that has been attached to the development issue. You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
Please let me know if you need more information.
Hi Rob,
I just discovered what i think might be the cause of my problem: The "all"-Node is missing
Does the XamPivotGrid/XamPivotDataSelector need the "All"-Node to work properly?
BR
