I have a hierarchical xamGrid and I would like to let user to expand only one row. I.e. if another row gets expanded, first one collapses. I am trying to use RowExpansionChanged event, check all first level rows and set IsExpanded property for corresponding row. However I cannot use foreach for xamGrid.Rows collection:
foreach statement cannot operate on variables of type 'Infragistics.Controls.Grids.RowCollection' because 'Infragistics.Controls.Grids.RowCollection' does not contain a public definition for 'GetEnumerator'.
Also when I try to get xamGrid.Rows.Count I get a message:
'Infragistics.Controls.Grids.RowCollection' does not have a definition for 'Count' and no extension method 'Count' accepting a first argument of type 'Infragistics.Controls.Grids.RowCollection' could be found
I see Count and Item public properties for RowCollection class in online documentation. What did I miss ?
Ed
Hello Ed,
Thanks again.
Stefan,
Thank you very much, everything works fine.
Thank you for your post. I have been looking into it and I can say that this behavior occurs if you doesn’t have a reference to the InfragisticsWP4.DataMAnager assembly, so I can suggest you check and add the reference if you doesn’t have it.. Please let me know if this helps you or you need further assistance on this matter.
