What is the reason that I can't bind in xaml to the datasource attrribute of the sqlshapereader?
ie <igMap:SqlSharpReader DataSource="{Binding}/>
I would very much like to be able to do this so that when I update the data source the new values are bound to the map.
Currently I have to manually refresh this data in c#,which is clunky
sqlReader.DataSource = points;
theMap.Layers[1].ImportAsync();
is there a way to have the map points live update on the map? Is this a feature that is planned to be implemented.Thanks for your time
regards
Murray
Hi Murray,
We will try to support this behaviour in one of our future releases. Also you can submit a feature request to Infragistics via http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
Thanks !
Ivan Kotev
Ivan Thanks for your reply,
Yes I am aware that that is how you do it at the moment.
I guess what I am asking is that is there a way to do it without manually callying the async.
The map control is the only one that I use that does not automatically refresh when the data changes.
For an example refer to your graphs, you bind a data source to the graph and when it changes the graph redraws.
This is the behaviour that I would expect out of the maps. I assume that as of this version it does not support it. But maybe you could add it as a feature to incorporate in the future
Regards
Hi Murray
Curruntly SqlDataReader 's DataSource object is processed after a call to the ImportAsync() method. You can refer to this sample for more information: http://help.infragistics.com/NetAdvantage/WPFDV/2010.2/CLR4.0/?page=xamWebMap_Display_Geospatial_Data_from_SQL_Database_Server.html
If you have any questions, please let me know.
Best Regards
