HI All,
i wanted to change the header of the contentPane, after searching i did it by changing the template of the header of the contentpane and it works fine BUT
when the contentPane becomes a floating window a pantoolwindow appears and an additional windows border appears , and the point is, The paneheaderpresenter disappears.
i knew that the visibility of the paneheaderpresenter is depend on the panelocation property and in this state the header disappears.
i had an option to catch the toolwinowloaded event and then apply my template to the window but i dont like this because, if i did, and that window has more than one contentpane the header of each one will appear so i would have another top header for the window and i make buttons that operate on the content pane, so it will be miss leading, which content pane to apply the action?!
SO what i need now is:
the PaneHeaderPresenter is always Visible in any state
my final solutions that i reached now have problems
1- apply an style to the paneheaderpresenter element,
if i did it for any property like background, it works But
if i write
<Style TargetType="{x:Type igDock:PaneHeaderPresenter}"> <Setter Property="Control.Visibility" Value="Visible"></Setter> </Style>
to make the paneheaderpresenter visible in any case,
it fails!
and it seems that the binding is overriding my style
does anybody have a solution to this?
2- retemplating the contentpane (the header and the content)
i got this template from DockManagerGeneric.Xaml
<ControlTemplate TargetType="{x:Type igDock:ContentPane}"> <AdornerDecorator> <Border Background="{TemplateBinding Background}" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}" SnapsToDevicePixels="{TemplateBinding SnapsToDevicePixels}"> <DockPanel Margin="{TemplateBinding Padding}"> <igDock:PaneHeaderPresenter DockPanel.Dock="Top" Content="{TemplateBinding Header}" ContentTemplate="{TemplateBinding HeaderTemplate}" ContentTemplateSelector="{TemplateBinding HeaderTemplateSelector}" DataContext="{Binding RelativeSource={x:Static RelativeSource.TemplatedParent}}" Visibility="{TemplateBinding HeaderVisibility}" /> <ContentPresenter HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" VerticalAlignment="{TemplateBinding VerticalContentAlignment}" Visibility="{TemplateBinding ContentVisibility}" Content="{TemplateBinding Content}" ContentTemplate="{TemplateBinding ContentTemplate}" ContentTemplateSelector="{TemplateBinding ContentTemplateSelector}"/> </DockPanel> </Border> </AdornerDecorator> </ControlTemplate>
and i changed the line that contains the PaneHeaderPresenter Visibility binding :
instead of
i made it
Visibility="Visible"
and then i applied it to the contentpane
it worked !
the Pane header is visible in any case But
the content pane lost:
1- draging
2-context menu that change its stat (dockable, floating,hide...)
thank you .
Mahmoud ElShazly
Hi Stefan
How could I set this style at run time ?
Amit
Hello Mahmoud,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
Thank you for your post. I have been looking through it, tested your code and everything seems to work ok on my side. I attached a sample project that demonstrates that. Please let me know if this works fine for you.
I am looking forward to see hearing from you.
