Hello !
I 'd like to know if it's possible to add to the Axis an other Label type ? My axis define the unit with a label, good, but i want also define the type and the united of the axis.
For Example :
My primaryX Axis is labeled all the 1 units. Good but 1 is in cm ? m ? And what is labelled all the 1 unit ? day, week ? Is it possible to indicate this informations via the Axis or where i can put this information ?
Thank you for asking me.
Stéphanie
The Unit of 5 means the interval between the gridlines will be equal to 5. The labels will start from the axis min value + a multiple of the unit value. When AutoRange is set to true, the chart will pick the min value automatically, so there's no guarantee that axis min will be a multiple of 5. The only way that will happen is if you set an explicit Minimum and Maximum for your axis and set AutoRange to false.
Hello! Thank you for your answer, I have an another one. I generate a chart which I only set the unit on the Y axis. The Y Axis automatically set the MIN and MAX at -12 and -12.
For this Axis i want a unit of 5 therefore (5 and 10). However, by putting my unit at 5, AxisY generate dummy units. For the positive part he generates me units at 3 and 8 and for the negatives part he generates me units at -2, -7, and -12.
Why unit at 5 it is not taken into account?
Thank you for your reply. Regards
Stef
You can add units to your axis labels by using the label formatting. For example:<my:Axis.Label> <my:Label Angle="0" Format=" {0} cm" /></my:Axis.Label>This would add the word "cm" after each label on the axis
