Hi Folks,
I have a Datagrid with a csutom columns that has a button as a content. The button is visible for all rows. What I would like to do is to make the button invisible and set IsEnabled to false if an underlying ViewModel for this row is of certain type. I do have a converter ready, but don't know how to connect it to the FieldSetting. Is my approach completely worong here? If so how to set thi up?
Thanks!
<igDP:UnboundField > <igDP:UnboundField.Settings> <igDP:FieldSettings> <igDP:FieldSettings.CellValuePresenterStyle> <Style TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate> <Button Content="Command" Command="{Binding ShowPressureLossWindow}" Margin="3"/> </ControlTemplate> </Setter.Value> </Setter> </Style> </igDP:FieldSettings.CellValuePresenterStyle> </igDP:FieldSettings> </igDP:UnboundField.Settings> </igDP:UnboundField>
Hi Michal,
I am glad that you find my suggestion helpful. Thank you for using Infragistics components!
Best regards,
Bozhidara Pachilova
Hi Bozhidara,
this worked. Thanks a lot for help!
<igDP:TemplateField Name="FieldWithButton" BindingType="Unbound"> <igDP:TemplateField.DisplayTemplate> <DataTemplate> <Button Content="Additional Pressure Drop" Command="{Binding Path=(igEditors:TemplateEditor.Editor).DataContext.DataItem.ShowPressureLossWindowCommand, RelativeSource={RelativeSource Self}}" IsEnabled="{Binding Path=(igEditors:TemplateEditor.Editor).DataContext.DataItem.ShowButton, RelativeSource={RelativeSource Self}}" /> </DataTemplate> </igDP:TemplateField.DisplayTemplate> </igDP:TemplateField>
I am glad that you are having progress with implementing your requirement by following the TemplateField approach.
Regarding the Command binding, it is also a matter of configuring the correct path to bind the command. For example if it is a property on the ViewModel itself, which let’s say is the Window’s DataContext, it could be:
<igWPF:TemplateField.DisplayTemplate> <DataTemplate> <Button Command="{Binding Path=DataContext.Cmd, RelativeSource={RelativeSource AncestorType=Window, Mode=FindAncestor}}" CommandParameter="{Binding Path=(igEditors:TemplateEditor.Editor).DataContext.DataItem, RelativeSource={RelativeSource Self}}" >Execute command</Button> </DataTemplate> </igWPF:TemplateField.DisplayTemplate>
Please, keep in mind that this would depend on your specific application setup. Attached you will find another similar sample demonstrating such a button bound to a command.
Please, let me know if it helps.
Associate Software Developer
6761.XDGDisplayTemplateCmd.zip
Hi Bozhidara, I implemented this and it indeed works. However, I lost the command functionality as this doesnt work anymore with the new solution. Can you help me with this as well?
Command="{Binding DataItem.ShowPressureLossWindowCommand}"
Thank you for posting to Infragistics Community!
I would suggest defining the field containing a button as a TemplateField instead, as this approach would be more suitable for such a scenario.
In order to bind a property of an element within the DisplayTemplate to another field of the underlying Data item, you could use the following: extended syntax:
<igWPF:TemplateField Name="FieldWithButton" BindingType="Unbound"> <igWPF:TemplateField.DisplayTemplate> <DataTemplate> <Button IsEnabled="{Binding Path=(igEditors:TemplateEditor.Editor).DataContext.DataItem.ShowButton, RelativeSource={RelativeSource Self}}" >Button</Button> </DataTemplate> </igWPF:TemplateField.DisplayTemplate> </igWPF:TemplateField>
If you like to bind to the Visibility property instead, a Converter can be used, for instance:
<Button Visibility="{Binding Path=(igEditors:TemplateEditor.Editor).DataContext.DataItem.ShowButton, RelativeSource={RelativeSource Self}, Converter={StaticResource myConverter}}" >Button</Button>
For your convenience, I am attaching a small sample demonstrating this suggestion. Please, check it out and let me know if you need any further assistance on the matter.
Best regards, Bozhidara Pachilova Associate Software Developer
6747.XDGTemplateField.zip
