I would like to show the values from all series in one combined tooltip, like the picture below. Is that possible? If yes, how.
Hi Bin,
Yes, you are correct that the approach to retrieving the value under the mouse position for a CategoryDateTimeXAxis would be different.
Please, find attached an updated sample demonstrating a chart with a CategoryDateTimeXAxis and the custom CategoryToolTipLayer.
Let me know if it helps achieve your requirement.
Best regards, Bozhidara Pachilova
8306.XDCCategoryDateTimeAxis.zip
Thanks, I didn't recognize it.
I implemented that code now, but I get for the itemIndex always -2147483648
private void dataChart_MouseMove(object sender, MouseEventArgs e) { XamDataChart chart = sender as XamDataChart; Point mousePosition = e.GetPosition(chart.Series[0].RootCanvas); int itemIndex = (int)xAxis.UnscaleValue(mousePosition.X); Debug.Print(itemIndex.ToString()); if (itemIndex >= 0 && itemIndex < _viewModel.ChartItems.Count) { _viewModel.CurrentToolTipTimestamp = _viewModel.ChartItems[itemIndex].Timestamp; } }
I am using a CategoryDateTimeXAxis. Can that be an issue?
<ig:XamDataChart.Axes> <ig:CategoryDateTimeXAxis Name="xAxis" ItemsSource="{Binding ChartItems}" DateTimeMemberPath="Timestamp" Label="{}{0:HH:mm:ss}" MinimumValue="{Binding XAxisMinimum}" MaximumValue="{Binding XAxisMaximum}" Strip="Transparent" MajorStroke="Transparent"/> <ig:NumericYAxis Name="yAxis" Label="{Binding YAxisLabel}" MinimumValue="{Binding ChartSettings.YAxisActualMinValue}" MaximumValue="{Binding ChartSettings.YAxisActualMaxValue}"/> </ig:XamDataChart.Axes>
I am wondering if you have had the chance to take a closer look at the latest sample? I am asking this because, as mentioned in my previous message, there is code that serves to retrieve the index of the item under the current mouse position, so that the category name can be displayed in the tooltip as well. As I am not aware of your data model and the sample’s purpose is to demonstrate the CategoryToolTipLayer rather than specific data, the X Axis in the sample is not a Timestamp object, however the approach would be just the same.
Please, take a look at the below screenshot, where you can see that the category name “C5” for which the tooltip is currently displayed is also present in the tooltip text:
In case you need further assistance with anything specific, I could suggest modifying the sample with the relevant code and sending it back to me, so I can investigate it. If you have any other questions, please let me know.
Thanks for the example.
i would like to show the timestamp at the top of the tooltip. How can I access the series item?
Hello Bin,
Good to hear that this approach might be suitable for your scenario!
Regarding your latest query, please find attached a modified version of the previous sample demonstrating how to add additional text to the tooltip’s contents by specifying the PointerToolTipStyle property of the CategoryToolTipLayer and setting its Template. As you will see, there is also additional logic around retrieving the index of the item under the current mouse position, so that the category name can be displayed in the tooltip as well.
I hope this helps achieve your requirement. Let me know of any other questions on this matter.
3630.XDCCategoryTooltipLayer2.zip
