when a user selects any appointment and then press Alt Key and do drag drop on any other existing appointment in ultradayview/ultraweekview, i want the existing appointment to be replaced with the dragged appointment.
Basically i want a functionality where Alt+Drag drop will do an appointment replacement.
Chitra
The Key Modifier works for me, i am able to replace appointment on Alt+Drag drop.
There is one UI Issue i am facing, when i do Alt+drag drop, while dragging an appointment over existing appointment, the size of the appointments shrinks(Screen shot Alt+DragDrop.jpg). And as soon as i drop, the existing appointments get deleted and dragged appointment takes proper size.(Screen shot After_Alt+DragDrop.jpg)
Is there a way i can show them as overlapping existing appoinment with the dragged appoinment before replacing it.(i dont want to show that shrinking of appointments while performin alt+drag drop)
OR is it possible to show only Drag pointer while Alt+Drag Drop instead of moving appointment with mouse pointer while performing Drag-Drop.
I am just checking about the progress of this issue. Let me know If you need any further assistance on this matter ?
Thank you for using Infragistics Components
You could handle AppointmentDragging event and check which keyModifier (if (ModifierKeys == Keys.Alt )) was hold in order to perform your custom operations. More information about this even you will find on the following link:
http://help.infragistics.com/doc/WinForms/2014.1/CLR4.0/?page=Infragistics4.Win.UltraWinSchedule.v14.1~Infragistics.Win.UltraWinSchedule.ControlWithActivityBase~AppointmentsDragging_EV.html
Also I’ve implemented simple sample which demonstrates usage of AppointmentDragging event, in order to replace the appointment, please see attached sample.
