2745
Column chart formatting questions...
Hello!
I am new to the chart control and I have some questions.
I have created a simple data table to act as data source. It contains 3 columns, Label, Sales and Budget. The Label column is used as Labels on the x-axis.
1. How do I change the name of the Columns? What I mean is the name showed in the legend. Sales, Budget are english names and I would like to localize.
These names also showed up on the x-axis but I found a way to hide those labels.
2. Can I increase the gap between the vertical x-axis labels and the chart itself? I think that the labels are a bit close.
3. Is 0 the standard min value of the y-axis or do I have to change this to be sure in the future.?
4. How can I change the format of the values showing up when I run a the mouse over a column. The Y-axis was created using this code:
gantSalesBudget.Axis.Y.Labels.ItemFormatString =
"<DATA_VALUE:### ### ##0> sek"
Thanks!
