When I try to register the TreeNodesCollection of an UltraTree as a CAB-UIExtensionSite like this
RootWorkItem.UIExtensionSites.RegisterSite(UIExtensionSiteNames.WindowTemplatesTreeNodes, this.Shell.WindowTemplateNodes);
I get the following error message:
"No UIElementAdapterFactory register for type Infragistics.Win.UltraWinTree.TreeNodesCollection."
I checked with your documentation and it says
UltraTreeNodeThe following objects can be registered as extension sites: Nodes collection WinTree™ control individual UltraTreeNode element
Do I have to register a special AdapterFactory as stated in the error message or what else might I do wrong?
Thanks in advance and best regards, Gerald
Sorry Mark. I guess I missed the last post.
There isn't anything special you need to do with the ToolbarManagerWorkspace. Here is a Knowledge Base article on the ribbon and it is very similar
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10042
Also, here is a help article that shows you want you can register as an extension site:
http://help.infragistics.com/Help/NetAdvantage/WinForms/2009.1/CLR2.0/html/Win_UIElement_Command_Adapters.html
Well, I'm glad Infragistics is as proactive as other providers. Two weeks later and no answer. Good Job!
I have a similar issue with the ultraToolBarmanager (version 8.1.20081.1000). I can't seem to get it to register. Is there a factory similary to the TreeUIFactory?
You can take a look at the following knowledge base article that does it for the ribbon. You will find the code in ModuleControler.cs. Follow the same methodology for the a tree node.
Hi, sorry for late reply, my problem is that i cannot find a way to link a node click action with a CAB command. Is there a way to do this?
