I have created a DockAreaPane and set its ChildPaneStyle = ChildPaneStyle.TabGroup. When I populate this pane with multiple child panes the tab headers display just fine. However, when I have only added one child pane into the DockAreaPane the pane caption is displayed but there is no tab header displayed. Then, if I add another DockableControlPane, tab headers appear for both panes.How can I make a tab header display in the DockAreaPane regardless of the number of child panes it has?
(I know that what I am asking for is not exactly how Visual Studio works, but it is what I need for my application).
Thank you.
Dave, I would indeed like to take to take you up on your offer to submit a feature request. However, the priority of my specific need is not critical at the current time.
Thank you,
--Ray
Dave,
If Ray doesn't take you up on your offer to to submit a feature request, I will. I came to the forums searching for info on the very same idea.
Hello Ray,
If you'd like, I could submit a feature request for this behavior on your behalf. Please let me know how you'd like to proceed.
Matthew,
Thank you for your initial quick response. However, I have not seen any more activity on the matter. Is this still an active support case?
I created a case for you with our Developer Support, you should be contacted shortly by a DS Engineer to continue this case.
My gut instinct says it isn't really going to happen as the control isn't designed with this in mind but it needs a thorough look through before I say for sure.
