i have a VS 2005 VB.Net application with WinGrid v 7.3.20073.1043
I have added a dropdown to the form which i populate from a data source object.
it is then a reference to a field in a grid as a dropdown for a cell. When i run the program, the cell functions properly. The dropdown allows me to select the item and it updates the grid.
however, my customer cannot select a value. She can click on the dropdown which displays the values, but she is unable to select an item.
this is quite a problem for them. Any suggestions?
She is running on Windows XP Pro, I am running Vista. I can run it on their Windows 2003 server and it works fine.
Thanks, Harold
Harold Lanier said:also, i can't remember if i mentioned it previously, but when i log onto the remote computer as an adiminstrator, the dropdowns work fine
That's very strange. That seems to indicate that there is, in fact, some kind of permissions issue happening. But I can't imagine any issue of permissions that would prevent the dropdown from handling a click that was directly on it. And if the item is getting highlighted, then clearly the dropdown is receiving the click message.
Harold Lanier said:Would re-registering the .dll's make any difference?
I doubt it. It can't hurt to make sure your development PC and the client machine are using the same versions of the Infragistics assemblies. But since it works for you remotely logged in as an admin, the assemblies are obviously working in some cases.
also, i can't remember if i mentioned it previously, but when i log onto the remote computer as an adiminstrator, the dropdowns work fine. Would re-registering the .dll's make any difference?
The dropdowns in the parameter section are Windows ComboBox controls. They work fine.
Double click doesn't help.
Do the dropdowns in the parameter selection box below the grid exhibit the same behavior? Does double clicking on the item in the dropdown do anything?
Nick
Clicking on the list will highlight the item, but not select the item and close the drop down. Keyboard doesn't work either. Enter key doesn't work.This is a windows application, not a web application.
They have the same issue when running via Remote application or on their local XP computer.
