Hi
1. Is there any possibility how to change a footer in WinGridPrintDocument only on the last page of printed document (grid)?
I need to display different text in footer of last page.
2. Can I format text displayed in header / footer section.
Is it possible to display e.g. text in TextLeft as bold and text TextCenter text as normal text but with bigger font size?
I checked into this a little further and it looks like I was wrong, the headers and footers are not UIElements. So there is no way to do this with the UltraGridPrintDocument.
If you use the built-in printing functionality of the grid, you can do it, but then you lose all of the UltraGridPrintDocument functionality.
You should Submit a feature request to Infragistics and suggest that some way be added to customize the headers and footers in mode detail.
Yes, I'm using UltraGridPrintDocument. Is somewhere any sample of usage DrawFilter or CreationFilter in printing process.
I don't beleive there is any way to do either of these things using simple property settings. But you might be able to achieve these using a DrawFilter or a CreationFilter. But it would be pretty tricky, and I'm not sure it's actually possible. It may depend on how you are printing. Are you using the grid's built-in printing or the UltraGridPrintDocument?
