hi there,
i have updated a project from 7.2 to 10.2, i also save a lot of layouts for the ultradockmanager.now i cant read the oldlayout in the new version.
i had the same problem with the ultragrid, but i found a solution for convertig old layout´s. this solution does not work with the ultradockmanager.
has anyone an idea for migrating ultradockmanager layouts?
thanks
Michael,
I have not been able to reproduce this effect on my end. Would it be possible for you to send me a simple demo project that demonstrates this behavior?
Michael S.
Hi Michael,
No solution so far. No further response from Infragistics.
I've downgraded to 10.1 :((
Frank
hi frank,
did you find any solution for the flickering/shaking problem?
Michael Runda
Hello Michael S.
i made some changes in my application. now i´m using xml files instead of binary files. i changed the version string in these files from v.7.2 to v.10.2 and my problem was solved. this procedure also works with grid layout files.
now i try to solve the flickering/shaking problem wich is described by an other user in this task. the flickering/shaking apears when i change the focus from one grid to an other.
thank´s for help
I've made a capture. You can't see the mouse but you meight imagine.The "classview" shakes when I ckick in it. This effect only appears in the 10.2.
