I'd like to build a grid with different items ( these items have "families")
the grid is ordered by family and items names
I'd like to know if for each family I can have the summary of the items (quantity and value) at the en of the items of the family ?
ex:
item1 qty1 value1
item2 qty2 value2
total family1 qty1+Qty2.... value1+value2+......
itemf1 qtyf1 value f1
itemf2 qtyf2 valuef2
total family 2 ..........................
I "managed" to do this by going through the grid and add row and move them
but when I want to print the grid ou export it into an excel file i get all summaries at the en of the grid ...
How can I do it ?
You can control the display of the GroupBbyRow in a couple of different ways.
1) You can set the GroupByRowDescriptionMask property.
2) You can handle the InitializeGroupByRow event and set the Description property of the row to any text you want in whatever language you want.
You can also use InitializeGroupByRow to expand the row.
I tried to use the outlookgroupby viewstyle , but It puts the number of different items and not the values...
It is written in english ( as I work for french people I'd like to be able to translate items ) and more generally all things written in english in the infragistics components like in the outlookgroupby
I'd like it to be expanded too by default...
If I understand correctly what you are trying to do, you could bind the grid to a flat list of data and add a summary, then use the OutlookGroupBy feature to group the grid by family and the summaries would be broken up into sub-totals like you have here.
