100
Code automatically changing when viewed in designer
I have several problems where design code is automatically changing when I open a form in the designer. In one example I have an explore bar control container that has it's location changed when first viewed. When I save and check in the changes the same thing happens next time I open the form.
I have other exapmples where it's an appearance object that has changed but I cannot seem to fix the problem. This is happeneing on net advantage 2009 vol 2 but has happened on previous versions. We have recently moved to VS team system 2008 and the files are being automtaically checked out and this is causing real problems.
Regards
