The Microsoft Office Fluent UI Design Guidelines state the Menus that exist on the Ribbon when at their large size must perform the default action when the image is clicked, and clicking on the text must show the Menu.
"1. For large split button controls, clicking on the icon MUST always perform the default action for the control 372 (i.e., either the first item in the menu or the most recently used item from the menu). Clicking on the text 373 label associated with the dropdown arrow MUST always display the menu. (Note in the figure below the 374 two parts of the Paste split button.)"
I can't seem to get this behavior to occur using the PopupMenuTool with the 2008 version of the Infragistics control suite.
Is there a setting that I am missing somewhere, or is this something not implemented by the Infragistics Ribbon?
Set the DropDownArrowStyle to SegmentedStateButton instead.
I hope you don;'t mind a followup.. When I set Checked=true to the popupmenutool it doesn't draw using it's pressed appearance...
DisplayStyle is set to ImageAndText.
Cheers,
Mark
On the PopupMenuTool, set it's DropDownArrowStyle property to DropDownArrowStyle.Segmented.
