Hi there !
How can I display NO decimals in the UltraCurrencyEditor ?
I've tried like this:
e.Row.Cells[
"BaseAmount"].EditorComponent = ultraCurrencyEditor1;ultraCurrencyEditor1.FormatString = "N0"; //still displays 2 decimalsThis works for a normal cell in the Grid, but apprantly not for the UltraCurrencyEditor?I want amount to be displayed like this:667.555 kr. but it is like this now 667.555,00 kr. <-- I want to REMOVE the ,00 !?
Kind regards,EE.
Hello EE,
As I understand you - you want to have the 2.000.000 values like when in edit mode and when not in edit mode? If so, you could set your mask and format to n.nnn.nnn #.###.###.
Please feel free to let me know if I misunderstood you or if you have any other questions.
hmmmm, there is one problem with this though ...
You loose the "." in between when WRITING in the box,e.g. I would like to see this RIGHT AWAY:2.000.000 instead of 2000000 and then having to TAB out of the control to see the 2.000.000
Any solution to this also ??
rgd,EE.
Works like a charm !
MY MAN ;-)
Maybe set the MaskInput to a value like this:
string currencySymbol = System.Globalization.CultureInfo.CurrentCulture.NumberFormat.CurrencySymbol;string mask = string.Format("nnnnnnnn {0}", currencySymbol);
Hi There,
It's working excellent NOT in edit-mode ( i.e. not using the CurrencyEditor ) like this:I'm also able to make it appear correctly in the CurrencyEditor ( e.g. no decimals ) BUT then I lose the ".- KR" ( currency )
/*ultraCurrencyEditor1.FormatString = "c"; ultraCurrencyEditor1.MaskInput = "nnnnnnnn"; ultraCurrencyEditor1.PromptChar = ' ';*/
e.Row.Cells["BaseAmount"].EditorComponent = ultraCurrencyEditor1; e.Row.Cells["MaximumAmountWithBranchAuthorization"].EditorComponent = ultraCurrencyEditor1;
This is the stuff that get's the cell's correct NOT in edit-mode:
e.Layout.Bands["TransactionAuthorizations"].Columns["BaseAmount"].Format = "N0"; // setur punkta og enga aukastafi, sem er flott e.Layout.Bands["TransactionAuthorizations"].Columns["MaximumAmountWithBranchAuthorization"].Format = "N0";
but the UltraCurrencyEditor is giving me pain .......
How would you do this exacly ?
