165
Application freezed
Hi there,
I've got a strange behaviour using DockManager
- I create a new 'Windows From Application'
- I create a UserControl that contains a DataGridView (Microsoft's one)
- In the form, I add the Dock Manager
- In the form, I create two dockable panels. The first one contains my user control and the second one is empty. These two panels are in the same dockable area (so I have 2 tabs)
- I build and launch the application. Everything is fine
- But... there is a 'but'... In the datagrid, if I enter in Edit mode for a cell and then I click on the tab to activate the second panel, the application is freezed. We always receive the 'Leave' event for the usercontrol !!
If I replace the user control directly by the datagrid it works but I can't close the application anymore using close button in the caption bar.
Do you have this issue ? Is there a workaround ?
PS: this issue happens only if the two panels are in the same dockable area (so 2 tabs)
PS2: I'm using v8.3 CLR2.0
Thanks for your help
