Im having trouble finding the setting for styling the form in appstylist. With the styles that come with Appstylist, this is set somehow, I just dont know where. View the attached image for what im talking about.
Thankyou in Advanced :-)
Corey
Hi Corey,
You can't e-mail me directly. You can attach files to your post here or, if you want to send something you don't want publicly posted, you can Submit an incident to Infragistics Developer Support.
Am i able to send a private email to you with the actually colours im trying to achieve?
I'm confused. I think I have already given you two solutions. One is to use a blend color. The other is to set the colors on the individual UIRole roles.
What more are you looking for here?
I need to do what ever it takes really, i have styled the rest of the app, mind you the image I posted isnt the app colour im using as i dont want to post it publicly but i notice if you use say the blue style, that the textboxes normal state has they blue tinge to it until you roll over to give it focus then it white, these are all linked to the same colour im trying to get right.
If there is a solution to my problem regardless of how involved i would appreciate if you could guide me in the right direction.
Cheers
No, there's no other way, other than to blend with an existing color scheme. You need an existing sceheme to provide different shading, otherwise, everything would just be one solid color.
You can, of course, explicitly set the colors of each UIRole, but that's a lot more involved.
