Hello, After installing a hot fix for 2007 Vol 3, I am able to compile but not able to run the application correctly. Any help would be appreciated! After installing the hot fix, I ran the Project Upgrade Utility as well as deleting dlls in project bin directory and obj directory. The code compiled without any problem but when I run the application through Visual Studio 2005 debugger, I am getting below error:
Additional information: Could not load file or assembly 'Infragistics2.Win.UltraWinToolbars.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
Same happens for UltraWinGrid. The version for hotfix should be 7.3.20073.1061 and the dlls referenced in the project is also 1061 but somehow, when application is running, 7.3.20073.38 (original 2007 vol 3 version) is being used. In GAC, correct version 1061 is displayed for infragistics dlls.
I called the phone support and support technician said it might be due to hot fix not installed correctly. Following his recommendation, I uninstalled 2007 Vol 3 and reinstalled 2007 vol 3 and the hot fix again. I didn't see any problem while installing both but I am still getting the same error. Thank you in advance!
Thanks Vince and Ammar for quick response. There was references in one of the prerequisite dlls I didn't notice so once I upgraded all dlls, everything works fine.
The reason for this could be 2 things, First, the reference to NetAdvantage assemblies are marked with "Specific Version" = True which is the default. You need to Change this False. In Solution Explorer Tab select all Infragistics assemblies and in the properties tab set the "Specific Version" property to Fasle.
The other reason might be the licenses.licx file in the project. open this file and clear its content. Do not delete the file
Please let me know if these 2 steps fix the issue and mark this post as confirmed fix if that is the case.
Ammar
I recommend that you continue working with Developer Support on this issue.
My best ***ment at this stage is that there's likely some lingering reference to the 7.3.20073.38 build, possibly somewhere that our Project Upgrade Utility doesn't touch. For instance, you might still have the 7.3.20073.38 assemblies in the bin of your project (or possibly of a prerequisite project).
