I show UltraProgressBar in a column of UltraGrid using _grid.DisplayLayout.Bands[0].Columns["Progress"].EditorControl = ultraProgressBar1; and make the rows of the grid resizable using _gridActionInfo.DisplayLayout.Bands[0].Override.RowSizing = RowSizing.AutoFree;
When resizing the row, the progress bar in the cell is also resized: the height of the progress bar is always the height of the row. Now I want to keep the original height of the progress bar when resizing the row: when row height changes, the height of the progress bar won't change. How can I make this happen?
Thank you, Matt.
I will try the CreationFilter. Hope it works.
-Fang
I'm not really sure that this is possible, since the grid needs to fill the contents of the cell with what the editor provides; properties like MaximumSize on the control are not respected for the embeddable editor. You might be able to do this with a CreationFilter, ensuring that you position the ProgressBarEmbeddableUIElement such that it is not changed in height. If you think that you might want to go this route, the UIElementViewer is a useful utility.
-Matt
