390
UltraCalendarInfo, DataBindingsForAppointments
When using a dataset with the UltraCalendarInfo.DataBindingsForAppointments, what determines when the Appointment data is committed/updated to bound dataset?
Most other infragistics controls such as the ultragrid have a property that determines when this update occurs ie ultragrid.updatemode.
The only time I have found that the update to the dataset from the ultracalendarinfo occurs is when the form containing the control is closed?
Thank you.
