Thanx in advance,
Yes. Context menus show up on a right-click by default. You can identify any area of the tree you want using the MouseMove and the UIElements.
Small clarification:
You wrote:
gbenshim said:4. Is it possible to add a context menu to the columns in the UltraTree (again: i use multi-column tree).
Yes. You would handle the MouseMove event of the tree and assign a context menu based on the current position of the mouse, but this is not very difficult.
My question:
I want it to be initiated by right click on a culomn, is this possible?
Hi Gilad,
gbenshim said:1. Is it possible to export data from UltraTree to Excel?
Anything is possible. But there is no built-in functionality to export a tree to Excel. You would have to write your own code to loop through the tree and create the excel worksheet using the Infragistics Excel engine.
gbenshim said:2. If i use multi-column tree, is it possible to add a column chooser?
No, there is no ColumnChooser that works with the tree. Again, you could write one yourself.
gbenshim said:3. If i use multi-column tree, is it possible to allow use to mark multiple lines?
You can select multiple nodes if that's what you mean.
