Hello Team,
I have a requirement where I need to create a map attached in this post. For this requirement I followed the below steps
2) Created a new winforms application, added a new Form, inserted a UltraZoomLayoutPanel and Dock property to fill.
3) Inserted a UltraPictureBox on the above panel and set the Image property to the above created Map1.bmp and Dock property to Fill.
4) On this UltrapictureBox I placed few label controls.
The final form looks as below
Now my requirement is when the user zoom's or resize the form, the map should zoom accordingly along with the label controls over it. The UltrapictureBox zooms accordingly but the Label controls placed on this Ultrapicture box do not resize accordingly. Is there any way to resize the label controls as well when Ultrapicture box is resized?
Hello Mike,
Thank you for the update. It make's sense to have a nested zoom panel. I will write up a new product idea soon.
Hi Baba,
After investigating UltraZoomPanel and doing some research, nested zoom has been determined to be a product idea. You can suggest new product ideas for future versions on our ideas site.
Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case.
Thank you in advance for submitting your product idea.
