Is there a way to export a WinGrid with more than 256 columns to excel spliting the data into several worksheets?
I tried the following code but I still get an exception:
ultraGridExcelExporter.FileLimitBehaviour = FileLimitBehaviour.TruncateData;
int startColumnIndex = 0;
Workbook workbook = new Workbook();
if( worksheetNumber > 1 )
ultraGridExcelExporter.Export( m_dataGrid, worksheet, 0, startColumnIndex );
startColumnIndex += 256;
worksheetNumber++;
//write to file
BIFF8Writer.WriteWorkbookToFile( workbook, fileName );
Santiago Blanco
Hi Santiago,
The problem is with your call to Export. Your code here seems to be making the assumption that the startColumn is the starting column in the grid. It is not. The startColumn is the starting column where the grid will be exported to in the worksheet. So you are basically telling the exporter to start exporting the grid at a column that is outside the valid range. So this method you have here won't work.
I think what you would have to do here is export the grid multiple times, like you are doing, but rather then specifying the start column in the export method, you will need to hide the grid columns in the layout.
So you would use the BeginExport event of the UltraGridExcelExporter and hide all of the column in the grid except the ones you want to export to the particular worksheet. So the first time through, you would hide everything after the 256th column. The second time through, you would hide columns 0-255 and then everything above 512
Thanks for the response Mike.
I am already hiding some of the columns on the grid. Do I have to keep track of those columns to restore the grid to its previous state or there is an easier way to do that?
It would be nice in a future version of the grid to have the option to define the start and end source columns to export. I know that Office 2007 increased the limit to 16K but it would still be useful.
You don't have to keep track of anything you hide. If you trap the BeginExport event on the UltraGridExcelExported, the event will pass you a Layout. This layout is a clone of the grid's layout. So you can modify the layout any way you like and it will not affect the on-screen grid. So all you have to do is keep track of which group of columns you are exporting in each Export operation and hide all but those columns.
BeginExport is now obsolete. It was replaced with ExportStarted.This was done in order to support asynchronous exporting.
skalyniuk said:All but the last spreadsheet is blank. Any suggests / examples please?
I'm afraid I don't have any guesses as to why this is happening without seeing your code. Something you are doing in one of the event must be hiding the columns or something. It's impossible for me to guess.
Can you post a small sample project here which demonstrates the behavior so we can check it out?
Hi Mike
Thank you for your prompt follow up. The ultragrid methods seem to have been updated somewhat since this thread started. I am using VB.net in VS2010. I have Infragistics 11.2. and I am using the CLR4 version of the controls.
There is no BeginExport method. I am trying to export a grid that has approx 100 rows but typically > 256 columns in to Excel 2003. I tried using the Hide column feature to export into > 1 spreadsheet is a single woorkbook but I cannot get it to work. All but the last spreadsheet is blank. Any suggests / examples please?
Thank you in advance for your help
I'm afraid I do not know what you are asking. Your last sentence appears to have been clipped or something.
Iam using VB in VS210 and the Infragistiscs4 version of the control in 11.2. There is no BeginExport only Export Started. I thought that I could do something like the following:
If e.Layout.Bands(0).Columns.Count >= 256 Then Dim columnindex As Integer Dim startColumnIndex As Integer = 0 Dim endColumnIndex As Integer = 256 Dim worksheetNumber As Integer = 0 Dim columnsCount As Integer Dim worksheetNameWithNumber As String = String.Empty columnsCount = e.Layout.Bands(0).Columns.Count While (startColumnIndex < columnsCount) columnindex = 0 worksheetNameWithNumber = worksheetName If (worksheetNumber >= 1) Then worksheetNameWithNumber = String.Format("{0}_{1}", worksheetName, worksheetNumber.ToString()) Dim oColumns As ColumnsCollection = e.Layout.Bands(0).Columns For Each oCol As UltraGridColumn In oColumns columnindex = oCol.Header.VisiblePosition 'If ((columnindex > 0) And ((columnindex > startColumnIndex) Or (columnindex < endColumnIndex))) Then If columnindex > startColumnIndex And columnindex < endColumnIndex Then oCol.Hidden = False Else oCol.Hidden = True End If Next worksheetNumber = worksheetNumber + 1 Dim ws As Worksheet = e.CurrentWorksheet.Workbook.Worksheets.Add(worksheetNameWithNumber) e.CurrentWorksheet = ws startColumnIndex += 255 endColumnIndex += 255 End While End If e.CurrentWorksheet.Workbook.Save(sfilename) But while I get the grid to export to the file, all but the very last sheet int the workbook is empty.Please help.
I've fixed a couple of issues with my previous code so I am posting the solution I got, in case someone else faces the same problem.
The main issue fixed is that with more than 256 columns the exported excel file didn't maintain the same order on the columns as the grid on the screen. That was because I was using column.Index instead of column.Header.VisiblePosition to the the column position on the grid.
Here is the code:
public void ExportToExcel( string worksheetName ) { using( DataGridExportDlg exportDialog = new DataGridExportDlg() ) { DialogResult result = exportDialog.ShowDialog(); if( result == DialogResult.OK ) { string fileName = exportDialog.FileName;
UltraGridExcelExporter ultraGridExcelExporter = new UltraGridExcelExporter();
Workbook workbook = new Workbook(); int columnsCount = m_dataGrid.DisplayLayout.Bands[ 0 ].Columns.Count; if( columnsCount <= 256 ) { Worksheet worksheet = workbook.Worksheets.Add( worksheetName ); ultraGridExcelExporter.Export( m_dataGrid, worksheet ); } else { int startColumnIndex = 0; int endColumnIndex = 255; int worksheetNumber = 1;
ultraGridExcelExporter.BeginExport += delegate( object sender, BeginExportEventArgs e ) { ColumnsCollection columns = e.Layout.Bands[ 0 ].Columns;
foreach( UltraGridColumn column in columns ) { int columnIndex = column.Header.VisiblePosition; if( (columnIndex > 0) && ((columnIndex < startColumnIndex) || (columnIndex > endColumnIndex)) ) { column.Hidden = true; } } };
while( startColumnIndex < columnsCount ) { string worksheetNameWithNumber = worksheetName; if( worksheetNumber > 1 ) worksheetNameWithNumber = String.Format( "{0}_{1}", worksheetName, worksheetNumber.ToString() );
Worksheet worksheet = workbook.Worksheets.Add( worksheetNameWithNumber );
ultraGridExcelExporter.Export( m_dataGrid, worksheet ); startColumnIndex += 255; endColumnIndex += 255; worksheetNumber++; } } BIFF8Writer.WriteWorkbookToFile( workbook, fileName );
OpenSpreadsheet( fileName ); } } }
