Do you have any examples (in C#) of placing charts inside a grid? I was thinking of using a single row dsh grid and placing different pre determined charts inside the cells , but I was wondering if it's better to use a grid for this purpose or flow layout. In your samples app that shows samples of Charts, grids etc, there is a row on top of the Chart samples that scrolls and when you touch one of the cells it opens that chart. Are those images or actual charts that are being used? and is that a single row dsh or a single row flow layout.
Kathy
Sure I can convert that class over for you.
See attached.
Hello Darrell,
Thank you, understood. I would like to have the FlipBoard sample translated into C#. I've done most of it myself, but am stumped on how to translate the init method in the GridCellLocation7CarouselCell. So, if I could get the GridCellLocation7CarouselCell translated that would be great!
Thanks again for you explanations and help
If you are talking about the sample, it's not resetting the data, it's changing the chart type depending on an index value. Attached is the same sample except I added a red label to each cell so you can see which line of data is being shown.
Thanks very much that it exactly what I wanted to do. One problem with it though, seems like the cells move but then the grid reverts back to it being in the original position. There must be some other setting that needs to be released. It's almost like the grid is automatically reloading after the cell is in the new position.
Any idea of how to fix this?
Thank you
Hello Kathy,
I modified the sparkling column sample to :
1) Use a single field multiple column datasource;
2) Enabled the datasource helper's AllowCellReordering to true
3) In the cell, disabled the chart's screen interaction by setting UserInteratcionEnabled = false. Since you want the grid to get the interaction not the lower chart object.
When running this I am able to move the sparkline charts around.
