I am using web excel exporter version 13.2 . But when I deployed my code to server it is not working for internet explorer.
Please help it asap.
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hello Tarun,
I have created a private case for you with number CAS-133614-S6G5X5. If you can't send it here, please go to your Infragistics Account select tab Support Activity and find the case that I've mentioned. You can send me there anything you want, and it will be visible only for us.
So you have deployed the sample that I've provided to you with my previous reply, and the same error appear again?
Could you please give me the link after you deploy the web site, in order to check it from my machine. When the error appear it will be easy for me to investigate it under my environment.
I did the same exact code. Deployed it on the server. But still IE 8 gives me same error.
Internet Explorer was not able to open this internet site. The requested site is either unavailable or cannot be found. Please try again
I also searched google and found that the problem is with response headers but I am not sure how to fix this.
