225
Excel support and Mono
Hi together,
I have a prroblem using Infragistics4.WebUI.Documents.excel on a Mono Environment. If I try to set the with of a column I get the following exception:
Could not open display (X-Server required. Check you DISPLAY environment variable) Parameter name: Display
Description: HTTP 500. Error processing request.
Stack Trace:
System.ArgumentNullException: Could not open display (X-Server required. Check you DISPLAY environment variable)
  at System.Windows.Forms.XplatUIX11.SetDisplay (IntPtr display_handle) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.XplatUIX11..ctor () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.XplatUIX11.GetInstance () [0x00000] in <filename unknown>:0
  at System.Windows.Forms.XplatUI..cctor () [0x00000] in <filename unknown>:0
Are there any workarounds to suppress the invoke of the Windows Forms Framework when i access the Excel classes.
Thanks for the help
