I am using Win 7 x64 and vs2010 premium
I have tried to use the toolbox utility for: 8.2, 8.3, 9.2, 10.1
The 8.x versions are command line and the others have a utility accessible from the start menu.
I have both vs2008 and vs2010 installed. I am able to use the toolbox utility successfully with vs2008 but all attempts with 2010 fail.
Here is the end of the file from the log when attempting to run the utility with 9.2:
02:04:17: Checking if Visual Studio version 10.0 is installed.02:04:17: Opened Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\VisualStudio\10.0.02:04:17: IsVisualStudioVersionInstalled returned True02:04:17: Checking if CLR35 is supported in Visual Studio version 10.0.02:04:17: IsClrSupportedInVisualStudioVersion returned True02:04:17: A product with the specified parameters was not found on the system or it is not supported in Visual Studio version 10.0. No folders containing assemblies were found.02:04:17: IsValidSetup returned False02:04:17: 02:04:17: Products that were successfully run:02:04:17: 02:04:17: ASP.NET product 9.2 CLR35 was successfully run with Visual Studio 2008.02:04:17: 02:04:17: Products that were unsuccessfully run:02:04:17: 02:04:17: ASP.NET product 9.2 CLR35 was unsuccessfully run with Visual Studio 2010.02:04:17: Finished.
Anyone have any ideas?
Hi all,
Please check the suggestions given in the following thread:
http://community.infragistics.com/forums/p/32608/246678.aspx
If the instructions give do not solve your issues you may try to create the toolbox manually. The following articles illustrate how this can be achieved:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Web_Getting_Started_Dragging_Assemblies_from_the_Bin_Folder.html
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Web_Getting_Started_Using_the_Choose_Toolbox_Items_Dialog_Box.html
Please contact me if you require further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://es.infragistics.com/support
I just hit that issue.
I really hope there is a more sane way to resolve it instead of uninstall and reinstall.
I had this same issue. I uninstalled and reinstalled Netadvantage for ASP.Net (and winforms) and then ran the toolbox utilities again and it worked fine.
I'm getting the same error.
Just installed VS2010. Installed 10.1 last week when we were using VS2008. XP SP3
Log:
A product with the specified parameters was not found on the system or it is not supported in Visual Studio version 10.0. No folders containing assemblies werefound.Products that were successfully run:Windows Forms product 10.1 CLR20 was successfully run with Visual Studio 2005.Windows Forms product 10.1 CLR20 was successfully run with Visual Studio 2008.Products that were unsuccessfully run:Windows Forms product 10.1 CLR20 was unsuccessfully run with Visual Studio 2010.
