654
Custom Appointment Form vs. Changing Infragistics' Form
Hello -
I have a need to add 1-3 custom fields to each appointment.  I've seen folks reference two possible options.  I'm wondering if anyone has experience with these options and can give any insight/advice.  Specifically I'm wondering about the UI side of things (this post explains the data side pretty well http://news.infragistics.com/forums/t/7683.aspx)
1) Custom Appointment Form: It sounds possible to write my own appointment form, and cancel the Infragistics dialog and open my own.  My question is, how much work is it to plug into the infragistics recurrence workflow (recurrence form, Occurrence/Series dialog etc.)?  Can the infragistics Recurrence form and Occurrence/Series dialog be reused with my custom Appt form?  Are there any other complications to get the proper events to fire (AddActivity, AddRecurrence, AddVariance, UpdateActivity, etc.)?  Is it worth going to this trouble for 1-3 custom fields?
2) Change the Infragistics Form:  I've seen a few posts that recommend sending data from the DB to hidden fields or javascript objects on the page.  When the dialog opens, send the custom info to the existing Infragistics page using the FieldValues javascript object.  Then customize the existing page/control with custom fields and consume the dialog's save event to send the custom info as hidden input.  Finally consume the ActivityAdded and ActivityUpdated events to send the custom info to the DB.  This seems like a lot of work too, but I don't know if it's appropriate for minor customizations.  It would be nice if this solution was cleaner too.
Any Thoughts/Advice?  Are there other options that I haven't listed?
  • 654
    posted in reply to Stephen Zaharuk
    Hello -
    I have a little more insight on my situation.  Another brain-dump is in this post (http://forums.infragistics.com/forums/t/12904.aspx).
    For the most part the details are the same as option 2.  The big difference is that I decided to add a WARP control to the appointment form.  This WARP control gets the custom data for the selected appointment.  This removes the need to send all custom data for every appointment on the MonthView/WeekView etc. to the calendar page, and then send that data to the Appointment page when an appointment is clicked.  Still not the best solution, but I think it's cleaner...
    -Brian
  • 40030
    Hi, I'd personally choose option 2. It's not really that much more work and would be a lot simpler than rewriting the entire Add Appointment Form. And you'd still have to send down your data and retrieve it the same way as option 2 suggests. I apologize for not having a cleaner approach for doing such a task. Hopefully in the future we'll be able to add a simpler way to pass custom appointment data between the client and server. If you have any problems while taking this approach, please feel free to respond to this thread. -SteveZ
  • 17
    Hi there, brassier.
    Unfortunately I still don't have any good answer for you. And it's a pity to see that none of these great guys from Infragistics still could lend you a hand. But no problem, I already got great help for these guys from their other replies in other posts and articles, it just seems that every answer I read will give me some light and then... nothing. Or it's just me who's a bad developer, but still I'll keep on trying. :-)
    I have a similar problem as you: still a bit stuck with this Appointment class extending (that post you mentioned is good, but it's kind of a "brain dump", and it isn't as detailed as the subject requires. I still have no success in extending Appointment class in such a way that I can use the WebSchedule controls (WebMonthView in my case), create or edit appointments, and receive my custom data back, and it's only one field. OK, I already know I can - and should - check the data independently, it's just that I thought I would be able to tailor it to my needs, and I was trying to do it the "cool" way. And I'm still trying to do that, some days into this already.
    Hope you have any reply, 'cause I'll probably use it too. I just won't use recurrences and this kind of stuff, just pure extra Appointment data.
