155
set the thickness of bar in gantt chart when vertical scroll is enabled
I'm using UltraWebChart for plotting Gantt chart
For y axis I have set the
RangeType="Custom"
RangeMin="0"
RangeMax="5"
using this thickness of each bar is fixed  even if I'm plotting only one Gantt Item.
But the above solution works only in case when vertical scroll is disabled.
Enabling the vertical scroll is increasing the thickness for the bar.
In my use case, I want to set RangeType to automatic (because data is dynamic) and fix the no. of gantt items to be displayed in one scroll window and also the height of each bar,
Is it possible?
