590
Tooltips for all labels
1) I want to show tooltips for labels which are on the X and Y axis. For custom chart the solution with creating CustomTooltips class worked fine
public class CustomTooltips : IRenderLabel
string _tooltip = String.Empty;
public string Tooltip
get { return _tooltip; }
set { _tooltip = value; }
#region IRenderLabel Members
public string ToString(System.Collections.Hashtable context)
if (!_tooltip.Equals(String.Empty))
return _tooltip;
if (!context["SERIES_LABEL"].ToString().Equals(String.Empty))
return context["DATA_VALUE"].ToString();
return context["ITEM_LABEL"].ToString();
#endregion
than Mouse move event looks like this
private void ultraChart1_MouseMove(object sender, MouseEventArgs e)
ChartLayerCollection layers = ultraChart1.CompositeChart.ChartLayers;
foreach (ChartLayerAppearance layer in layers)
bool success = false;
if (layer.ChartLayer != null)
var text = layer.ChartLayer.ChartCore.GetChartPrimitiveFromPoint(e.Location) as Text;
if (text != null)
labels.Tooltip = text.GetTextString();
success = true;
if (!success)
labels.Tooltip = String.Empty;
but now I am trying to do the same for bar chart like this
private void ultraBarChart_MouseMove(object sender, MouseEventArgs e)
ChartLayerCollection layers = new ChartLayerCollection();
layers.Add(barChart.BarChart.ChartComponent);
but I can't figure out what to add to "layers" collection.
Can you help me out?
The same question regarding TimeSeries chart.
2) The other question is when I apply this solution in composite chart which consist of column and line chart, the tooltips on line chart originally were showing Y axis values (which was good for me), after solution the show X axis values. How can I take back Y axis values?
