I have a WebMonthView that i'm applying css classes to each appointment.
like this... app.Style.CssClass += " DONOTOPEN"; where app is an appointment object in an AppointmentsCollection
protected void ColourAppointments(AppointmentsCollection app1, List<AppointmentObject> app2)
foreach (Infragistics.WebUI.WebSchedule.Appointment app in app1)
This works great when the page loads with data or posts back.
The WebMonthView has 3 tabs/active resources I'm handling the ActiveResourceChanging event....
void WebScheduleInfo1_ActiveResourceChanging(object sender, ActiveResourceChangingEventArgs e) { if (e.ResourceDataKey != "") { switch (e.ResourceDataKey) { case "3": CurrentResourceKey = "1,2"; break; default: CurrentResourceKey = e.ResourceDataKey; break; } FilterWebSchedule(null, null); //Refilter with the new resource key set ColourAppointments(WebScheduleInfo1.Appointments, CurrentCalendarAppointments); ColourAppointments(WebScheduleInfo2.Appointments, CurrentCalendarAppointments); ScriptManager.RegisterStartupScript(this, this.GetType(), "appointmenticons", "CreateAppointmentIcons();", true); UpdatePanel1.Update(); } }
this applies the CSS to the appointment objects again in ColourAppointments, but the objects aren't getting the CSS classes when i inspect them in the browser
Thanks Nikolay it would be nice to have it on.
Hi again.
I'm glad that you found a way to resolve your case. However note that disabling EnableSmartCallbacks will result in loading the entire page, which may affect performance. I'm trying to run your sample and isolate the problem and will reach you if I found a different solution.
Thank you for using our product!
Best regards,
Nikolay Alipiev
Software Developer
i think i found the problem, something about the smart callbacks aren't allowing the data to rebind correctly, i changed it to .... EnableSmartCallbacks="false" and that seems to have fixed it
https://www.dropbox.com/s/fljtltk30quvfal/TrainSchedule.aspx?dl=0
https://www.dropbox.com/s/gojamjexfx4x3s0/TrainSchedule.aspx.cs?dl=0
Hi Nikolay, thanks for the reply, i can give you the .aspx and .cs if you want
