I have installed infragistics V2010.3 But my objects are not highlighted when i run my script through RFT. But i can able to capture the window.When i tried to highlight it is not working.Can u please help on this issue.
Mani
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Hi Mani,
Thank you for the reply.
What is the OS that you are using (i.e. Windows XP, Windows 7, etc.)? Also you didn’t mention the version of NetAdvantage that the application under test uses. Please make sure that it matches the version of TestAdvantage.
Additionally, please send me the files located at "C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization"
Please let me know if you have any additional questions.
I can able to record the objects under test.But when i playback the test script the objects are not recoganised.
Thank you for contacting Infragistics Developer Support.
Please clarify what exactly you mean by “my objects are not highlighted”. I will also need to know the following details:
-Version of RFT
-Version of TestAdvantage
-Version of NetAdvantage that the application under test uses
-The OS that you are using. Is it 32 or 64 bit?
-Can you record or replay scripts on Infragistics objects
I am looking forward to your reply.
