I using the ColumnLayout object to display the link information like the follow chart:
But I find the problem when I click the [Invert Selection] button:
The first click the button, all rows could select or unselect by follow code:
CustomSelection customSelection = new CustomSelection(); for (int i = 0; i < this.m_MainGrid.Rows.Count; i++) { if (!this.m_MainGrid.Rows[i].IsSelected) { customSelection.AddSelectItem(this.m_MainGrid.Rows[i]); } }
this.m_MainGrid.SelectionSettings.SelectedRows.Clear(); this.m_MainGrid.SelectionSettings.SelectedRows.AddRange(customSelection);
But when I click the [Invert Selection] button again, the problem happen:
The speed of traverse the XamGrid.Rows very slow(May be several minitues)!
I try to do not add the ColumnLayOut to the XamGrid, the problem not exist,
So I think the ColumnLayOut will be affect the speed.
I update my sample DemoTest.zip , please try it, thanks! The Infragistics version is 10.3.20103.2098
The operation step:
1 Click [Data Load] button, then data will be loaded.
2 Click [Invert Selection] button, then all row will be selected.
3 Click again [Invert Selection] button, then the page will be not responded.
Bug 100636 has been resolved and the latest service release is available under your account at the Infragistics Website. To download the service release, log in to ‘Account’ and select ‘Keys & Downloads’. Select the NetAdvantage tab and then click on the product name. The available service releases should now be listed on the page underneath the tab control.
Thank you, I will be wait for the next release.
This is a bug and I have created a item in our system to have it resolved. The bug number is 100636. Our developer support staff will contact you with a case so you can track this item through our system.
Anyone could answer this question?
Hi, anybody can answer this question? Thank you.
