715
map.ElementClick event not firing
I use XamMap with two layers (.shp file layer and SymbolLayer)
The map.ElementClick event gets fired for the SurfaceElements in the shape file, but not for the elements in the symbollayer.
 <igMap:MapLayer x:Name="shpLayer" DataMapping="Name=MicroMarket; Value=MetricValue" ToolTip="custom tooltip: {Value}"   FillMode="Chloropleth" Imported="MapLayer_Imported">
                    <igMap:MapLayer.Reader>
                        <igMap:ShapeFileReader Uri="shapefile" DataMapping="Name, Caption=Id" />
                    </igMap:MapLayer.Reader>
                </igMap:MapLayer>
 <igMap:MapLayer x:Name="symbolLayer" VisibleFromScale="55"  >
                    <igMap:MapLayer.ValueTemplate>
                        <DataTemplate>
                            <Image Source="{Binding ImageUrl}" ToolTipService.ToolTip="{Binding ToolTip}" />
                        </DataTemplate>
                    </igMap:MapLayer.ValueTemplate>
                </igMap:MapLayer>
                map.ElementClick += (s, e) =>
                    if (e.Element != null && e.Element is SymbolElement)
                     //doesn't come here :(
                    if (e.Element is SurfaceElement)
                        MessageBox.Show(string.Format("You clicked surface element {0}", e.Element.Name));
If I add an eventhandler on the Image_MousLeftButtonDown for the image it works, but I rather have the map.ElementClick because I want to add the event in another class where I have access to the map and I can handle the clicks in one cosistent way.
Thanks in advance
