may you confirm me that javascript errors in asp.net classic controls due to incompatibility with IE9 can't be solved by simply switching to Compatibility View and / or IE8 Browser Mode?
I'm using suite 2007v3.
Best regards, Andrea Pirola
good! thanks for your help, I will check version 12.1
regards,
Fernando
Hello Fernando,
1. Yes, older versions of IE are also supported.
2. You should replace UltraWebGrid and the other retired controls - for more information on this check this thread: http://blogs.infragistics.com/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx.
3. You can download NetAdvangate trial version from this page - http://es.infragistics.com/dotnet/netadvantagedownloads.aspx#Downloads.
Feel free to contact me if you have any further questions.
So,
1. version 12.1 supports *older* versions of IE too?
2. Migrating to version 12.1 means to replace UltraWebGrid by WebDataGrid?
3. How could I test version 12.1? can I download a trial version?
thanks for your help.
Hello fpardo,
NetAdvantage 10.1 supports IE 6 to 9 and the other browsers you mentioned, but not their latest versions. For the most extensive browser support I would reccoment you to upgrade to the latest version - NetAdvantage 12.1, which supports all these browsers, including their latest versions.
Hi! thanks! but my question is not about which version supports IE9, my question is:
NetAdventage v10.1 supports IE6 to 9? chrome and Firefox?
I need to know if it supports all IE versions (from 6 to 9) and other web browsers, in order to migrate to it.
Thanks.
