335
Cambiar la visualizacíon del mapa entre dos valores
hello
I have a map that reads the information from the SQL Server.
Get from the database to represent 2 values.
Clik Using a listbox, I want to be shown on the map with the value 1 or the value 2. The ultimate goal is to display the same as when you load the map the first time (by default with the value 1)
Like the example http://labs.infragistics.com/silverlightdv/2010.3/ # / Samples / Map / BindingWCFDataFilteringSource
If I do as an example, does not load any data.
If I do it with the following code, the map changes but does not display any data:
 Private Sub OnDataChanged(ByVal sender As Object, ByVal e As SelectionChangedEventArgs)
        Dim ItemSeleccionado As ListBoxItem = sender.SelectedItem
        Dim TextoSeleccionado As String = ItemSeleccionado.Tag.ToString
        Dim converter As New DataMapping.Converter()
        Select Case TextoSeleccionado
            Case "Facturacion"
                Dim sqlReader As SqlShapeReader = TryCast(xamMap.Layers("CapaAutonimias").Reader, SqlShapeReader)
                sqlReader.DataMapping = TryCast(converter.ConvertFromString("Data=geom;Name=NAME_1; Caption=NAME_1;Value=ValorF"), DataMapping)
                xamMap.Layers("CapaAutonimias").Reader = sqlReader
                xamMap.Layers("CapaAutonimias").ToolTip = "{}{Name}: Facturación {Value:n0} €"
            Case "Ventas"
                sqlReader.DataMapping = TryCast(converter.ConvertFromString("Data=geom;Name=NAME_1; Caption=NAME_1;Value=ValorV"), DataMapping)
                xamMap.Layers("CapaAutonimias").ToolTip = "{}{Name}: Ventas {Value:n0} Uds"
        End Select
        xamMap.Layers("CapaAutonimias").DataBind()
