I have a project, in which on the Default webpage I have a webgrid. My webgrid populates correctly, and what I am wanting to do is have an "Edit" form open up, once a record is selected by clicking on a webgrid button.
I am so far unable to pass the ID from the Default page webgrid to the Edit page. I have found code using the "PreviousPage" property, but I have had no luck with this.
I added a hidden text box to the Default webpage to store the ID of the webgrid, once the webgrid button is clicked, but I have played around and found that the page must refresh before the text box stores the ID of the webgrid. So when I open up the Edit page, the text box is still empty.
I believed this would be pretty easy, but I have not been able to pass the webgrid ID from the Default page to the Edit page.
Am I going about this wrong (trying to store the WebGrid ID to a text box, and using the PreviousPage property in ASP.Net)?
Thank you for your help.
T.J.
Instead of opening a new page in order to edit the contents of the row, you could also use the WebDialog control.
Hi!
U can also use Session or ClientQueryString to pass the information to the other page.
Charuk
