Is it possible to create each layer with its own Y axis so that each layer has its own range but not display the axis? If I set visibility of the axis to collapsed then the layers do not get drawn.
Can you shoot myself (jasonb@infragistics.com) or Devin (devinr@infragistics.com) and email and we can get you some pre-release bits on the chart that might be able to help you.
Jason
I tried setting the MarkerToolTipFormat to "{Value:G}" but nothing gets displayed. However if I change it to "Value = blah" the string does get displyed. Using this code for the tooltipformat seems to work fine: layer.ToolTipFormat = "{Layer.Title}"; but using the {} to reference anything in my GaugeReading object (using {Layer.Title} works fine) seems to prevent anything from the MarkerToolTipFormat from displaying. Am I not referening the object correctly?
It would be great to get a more complete explaination of your scenario. If each axis has a seperate range but is hidden, how are you indicating to the end user the range of the graph? Or does it just not matter in your scenario?
Feel free to drop me an email if your willing to spend a bit of time helping us understand what your app is doing that requires this. devinr@infragistics.com
Thanks!
Devin
There may be a way to reduce the width of those axis label panels to 0 or near zero, I'll have to check that version of the chart to make sure. The way they are structured has changed since the CTP.
You shouldn't need {} when you are setting the property programattically. {} is required when you set the property from Xaml to let the Xaml parse know that your attribute that starts with a { is NOT a markup extension. Those characters are not passed along to the actual property. So try:
layer.MarkerToolTipFormat = "{Value:G}";
-Graham
I havent tried rendering the Y axes transparently as having more then one still takes up space and pushes the chart over even if I get it to be a transparent color, right?
Along these lines I cannot seem to even get the marker tooltips to be displayed. Pretty much everything is being added programatically so what I pass to the chart area is a Queue<GaugeReadings>. I am uncertain what to set the MarkerToolTipFormat to inorder to display the value. Here is the GaugeReading structure:
public class GuageReading{ public DateTime Time { get; set; } public double? Value { get; set; } public string Units { get; set; }}
I set it up this way:layer.ValueMapping = "Value";layer.MarkerToolTipVisibility = System.Windows.Visibility.Visible;layer.MarkerToolTipTemplate = Resources["MarkerToolTipTemplate"] as DataTemplate;layer.MarkerType = MarkerType.Circle;layer.MarkerToolTipFormat = "{}{Value:G}";layer.ToolTipTemplate = Resources["ToolTipTemplate"] as DataTemplate;layer.ToolTipFormat = "{Layer.Title}";
Can you see a problem with my marker tool tip format? How do I get it to display the marker Y value?
