I have a Hierarchial Web Grid. Initialize is done on postback. AddRow is done using a js function leveraging igtbl_addNew. Update and delete of cells are handeled by the client side event of the grid (AfterExitEditModeHandler="AfterExitEditMode" ClickCellButtonHandler="CellButtonClick" BeforeRowDeletedHandler="BeforeDelete" AfterRowDeletedHandler="AfterDelete")
After i remove a row and then try to update a cell for any of the remainder rows under the same parent row it doesn't return the proper child nodes it return a object and its evaluation says "Children could not be evaluated".
Please help me.
Thank you,
Sugnesh
Another option is to loop from 0 to the value of the row's ChildRowsCount property, and use getChildRow() at each index. This is a more useful approach than using getChildRows() if you intend on performing some action on each row.
for (var i = 0; i < row.ChildRowsCount; i++){ var childRow = row.getChildRow(i);}
By the way, if you plan on deleting any of these rows, I suggest looping through the list backwards instead, so you don't miss anything:
for (var i = row.ChildRowsCount - 1 ; i >= 0; i--){ var childRow = row.getChildRow(i);}
Is there another way to get list of child rows without using row.getchildrows().
It will likely take some in-depth investigation to determine what's happening here. I can't tell based on the symptoms described here.
I suggest you submit a support request so that a Developer Support Engineer can assist you further. I don't entirely understand the scenario you've described, so the best thing you can include with your support request is a sample project that we can run and debug and which reproduces the symptoms you've described.
