Google font integration does not work. What should I do?Indigo say: Currently, we don´t support this Google font.Thanks
It still doesn't work, I'm sending logs to the mail.
Thank you
That message is meant for when a specific font fails to render, but it seems it's happening for every font. Perhaps something got corrupted in your installation.Could you try the following? - Close Indigo Studio - Go to: Documents\Indigo Studio\Settings\Fonts - Delete the Google Fonts folder - Start Indigo again
Then try to download only a few fonts to check if it's working.If it still fails, please send a zip file with the logs at: Documents\Indigo Studio\logs\to indigo@infragistics.com
Kind regards,PabloIndigo Team
Thank you for your interest.
All fonts are failing.I'm following these instructions help.indigodesigned.com/.../downloading-google-fonts
Originally I had an old version of indigo studio installed, where there was no possibility of google fonts at all, after the update there is a possibility to download but it still does not work.
I enclose a print screen:drive.google.com/.../view
Thank you a lot
Hi Jana,We're not aware of problems in the Google fonts feature.
Could you share more details about this issue?What steps you are following and what's the font that it's failing.
