1905
igTree - Drag and drop not dropping in the proper place.
The default insertion graphic is too small and difficult to navigate to for my users, so I override it with:
.ui-igtree-insertline {
border: dashed 1px @ElementFrameBackgroundColor1 !important;
border-radius: 5px;
height: 36px !important;
width: 100%;
Occasionally, when I drag and drop an item, it will end up inserting before the node that it was supposed to be after.
I created a jsfiddle to replicate the issue: http://jsfiddle.net/apmcmillan/4vnL55ao/16/
It does not happen all of the time, and I have not tracked down the exact steps to recreate, but if you run that jsfiddle, then drag node AAA0 to be down between AAB0 and AAB1...sometimes it will drop before AAB0.  If it does not happen when you try it, then Run the fiddle again and try the steps to recreate...it will eventually happen.
