HI,
I created a grid with columns manually, which binds to the grid via dictionary list. Some of my columns are date columns, with a specific date-format, but when the value of the column is null it, displays a default date value (0001/01/01), I want do not want to display any value when the datevalue is null, is this possible, I do not see any properties on the datecolumn to allow for this?
If I add the column as a text column it does not display the null value, but then I cannot format the date via FormatString property either, so I am in a catch 22, any suggestion welcome?
A development issue 257108 has been created and a developer is currently assigned to investigate this in depth.
I also created a private support case to follow up with you, CAS-197672-M4F6G9. You can access this case when signed into your Infragistics account and clicking Support Activity and view what is marked "In Development".
Thank you for the feedback
Please let us know ASAP if there is a solution for this we can use.
I am following up to inform you that I have reached out to our senior developers and I will follow up when more information becomes available.
I will raise this concern to our development team by tomorrow. I'll follow up with a more complete update soon.
This is surely an oversight? there will always be blank (null) dates somewhere or did Infragistics expect that date columns will always have values?
Is there a way for us to use a converter on a DateTime column to show blanks when the values are null?
