790
Filtering XamDataTree
I am having difficulties in filtering the XamDataTree using triggers and collectionviewsource.
My tree should switch between two Modes based Mode1(Default) and Mode2.
The Object Model looks like below:
Class NodeX
ObservableCollection<NodeX> Nodes{get; set;}
bool IsSpecialNode {get;set;}
public ObservableCOllection<NodeX> NodeXCollection {get; set;}  ===> bounds to XamDataTree's ItemSource.
Mode1: should show all the nodes irrespective of the flag (IsSpecialNode )
Mode2: Should show only the nodes whose flag(IsSpecialNode ) is set to true
Option1:
<ig:NodeLayout Key="Nodes" TargetTypeName="NodeBase" DisplayMemberPath="Name"
IsDropTarget="{Binding Data.ViewType, ConverterParameter={x:Static data:ViewType.FolderView},Converter={StaticResource ValueEqualsParameterConverter},Source={StaticResource ArticleListBindingProxy}}" >
<ig:NodeLayout.NodeStyle>
<Style TargetType="{x:Type ig:XamDataTreeNodeControl}">
<Style.Triggers>
<MultiDataTrigger>
<MultiDataTrigger.Conditions>
<Condition Binding="{Binding IsInMode2}" Value="True" />
<Condition Binding="{Binding Path=Data.IsSpecialNode}" Value="False" />
</MultiDataTrigger.Conditions>
<MultiDataTrigger.Setters>
<Setter Property="Visibility" Value="Collapsed" />
</MultiDataTrigger.Setters>
</MultiDataTrigger>
</Style.Triggers>
</Style>
</ig:NodeLayout.NodeStyle>
</ig:NodeLayout>
Option2:
ICollectionView Mode2View;
Mode2View = CollectionViewSource.GetDefaultView(NodeXCollection.Nodes);
Mode2View = CollectionViewSource.GetDefaultView(ProductCollection);
if (IsInMode2)
 Mode2View.Filter = IsSpecialNode;
else
Mode2View.Filter = null;
Mode2View.Refresh();
public bool IsSpecialNode(object nodex)
ICollectionView Mode2NodesView = CollectionViewSource.GetDefaultView(((NodeX)nodex).Nodes);
Mode2NodesView .Filter = IsSpecialNode;
if (Mode2NodesView .IsEmpty)
return ((NodeX)nodex).Items.Any(item=> item.IsSpecial);
return true;
Both the options doesn't work. Please help me in filtering XamDataTree.
Tree Structure: (There is always one root node and we should display that always)
RootNode
     Node1
          Node2
              Node3
     Node4
Sreeni
