860
How to use xamRibbon MenuTool in MVVM
This question is related to the question at: http://es.infragistics.com/community/forums/t/86353.aspx
I am also trying to use the MenuTool in MVVM. Trying to do what the original poster likes to do, I looked through all the suggested threads, however, I was not able to get the MenuTool to work.
Here's the XAML:
<igRibbon:MenuTool  Caption="Status" ItemsSource="{Binding MenuItems}">
    <igRibbon:MenuTool.ItemContainerStyle>
        <Style TargetType="{x:Type igRibbon:ToolMenuItem}">
            <Setter Property="Command" Value="{Binding SetStatusCommand}"/>
            <Setter Property="CommandParameter" Value="{Binding}"/>
        </Style>
    </igRibbon:MenuTool.ItemContainerStyle>
</igRibbon:MenuTool>
Here's the VM:
public class ViewModel:ViewModelBase
public ViewModel()
MenuItems = new ObservableCollection<string> { "Active", "InActive", "Test" };
SetStatusCommand = new DelegateCommand<string>(SetStatus);
public DelegateCommand<string> SetStatusCommand { get; set; }
private ObservableCollection<string> _MenuItems;
public ObservableCollection<string> MenuItems
       get { return _MenuItems; }
       set
             if (value != _MenuItems)
             _MenuItems = value;
             RaisePropertyChanged();
private void SetStatus(string status)
       var parameter = status;
When I click on the item from the menu drop-down, the SetStatusCommand was not fired.
What did I do wrong?
If you can prepare a simple sample showing how to use the MenuTool in MVVM will be a great help.
Thank you very much.
