I need to customize the cursor that is shown when re-sizing panes withing the dock manager. Instead of the black arrow (shown in attached image) I have to use some a white arrow. How to do that?
Hi rajaka,
The following style should do the trick:
<Style TargetType="{x:Type igDock:SplitPaneSplitter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igDock:SplitPaneSplitter}"> <Border Background="{TemplateBinding Background}" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}"/> </ControlTemplate> </Setter.Value> </Setter> <Style.Triggers> <Trigger Property="Orientation" Value="Vertical"> <Setter Property="MinWidth" Value="4" /> <Setter Property="Cursor" Value="SizeWE" /> </Trigger> <Trigger Property="Orientation" Value="Horizontal"> <Setter Property="MinHeight" Value="4" /> <Setter Property="Cursor" Value="SizeNS"/> </Trigger> </Style.Triggers> </Style>
The triggers in the above style control which cursor to use when the splitter is either vertical or horizontal.
Thank you very much!
