1855
Weird exception being caught, unsure what is causing it, looking for any ideas/help
Data: System.Collections.ListDictionaryInternal
Message: Object reference not set to an instance of an object.
Inner Exception:
Source: InfragisticsWPF4.Controls.Menus.XamDataTree.v14.2
Stack Trace: at Infragistics.Controls.Menus.IntermediateNodesManager.get_DataCount()
at Infragistics.Controls.Menus.NodesManager.Infragistics.IProvideDataItems<Infragistics.Controls.Menus.XamDataTreeNode>.get_DataCount()
at Infragistics.Collections.BindableItemCollection`1.GetCount()
at Infragistics.Collections.CollectionBaseEnumerator`1.System.Collections.IEnumerator.MoveNext()
at Infragistics.AutomationPeers.XamDataTreeNodeAutomationPeer.GetChildrenCore()
at System.Windows.Automation.Peers.AutomationPeer.EnsureChildren()
at System.Windows.Automation.Peers.AutomationPeer.UpdateChildrenInternal(Int32 invalidateLimit)
at Infragistics.AutomationPeers.XamDataTreeNodeAutomationPeer.Node_PropertyChanged(Object sender, PropertyChangedEventArgs e)
at System.ComponentModel.PropertyChangedEventHandler.Invoke(Object sender, PropertyChangedEventArgs e)
at Infragistics.Controls.Menus.XamDataTreeNode.OnElementReleased(XamDataTreeNodeControl element)
at Infragistics.RecyclingManager.PanelInfo.ReleaseElement(ISupportRecycling obj)
at Infragistics.Controls.Menus.Primitives.NodesPanel.ReleaseNode(XamDataTreeNode node, Boolean removeManager)
at Infragistics.Controls.Menus.Primitives.NodesPanel.MeasureOverride(Size availableSize)
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV, Boolean& hasDesiredSizeUChanged)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
at System.Windows.Controls.Border.MeasureOverride(Size constraint)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
at DevExpress.Xpf.Core.LayoutTransformPanel.MeasureOverride(Size availableSize)
at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
at DevExpress.Xpf.NavBar.NavPaneActiveGroupControl.UpdateDesiredInfiniteSize(Size constraint)
at DevExpress.Xpf.NavBar.NavPaneActiveGroupControl.<>c__DisplayClass5.<OnDataContextChanged>b__4()
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Inner Exception:
Stack Trace: at Infragistics.Controls.Menus.XamDataTreeNodeControl.ResolveDisplayElement()
at Infragistics.Controls.Menus.XamDataTreeNodeControl.AttachContent()
at Infragistics.Controls.Menus.XamDataTreeNodeControl.OnAttached(XamDataTreeNode node)
at Infragistics.Controls.Menus.XamDataTreeNode.OnElementAttached(XamDataTreeNodeControl element)
at Infragistics.RecyclingManager.PanelInfo.AttachElement(ISupportRecycling obj)
at Infragistics.Controls.Menus.Primitives.NodesPanel.RenderNode(XamDataTreeNode node, Double availableWidth)
at Infragistics.Controls.Menus.Primitives.NodesPanel.ArrangeOverride(Size finalSize)
at System.Windows.FrameworkElement.ArrangeCore(Rect finalRect)
at System.Windows.UIElement.Arrange(Rect finalRect)
at System.Windows.Controls.Grid.ArrangeOverride(Size arrangeSize)
at System.Windows.Controls.Border.ArrangeOverride(Size finalSize)
at System.Windows.Controls.Control.ArrangeOverride(Size arrangeBounds)
at MS.Internal.Helper.ArrangeElementWithSingleChild(UIElement element, Size arrangeSize)
at System.Windows.Controls.ContentPresenter.ArrangeOverride(Size arrangeSize)
at DevExpress.Xpf.Core.LayoutTransformPanel.ArrangeOverride(Size finalSize)
at System.Windows.Controls.DockPanel.ArrangeOverride(Size arrangeSize)
at DevExpress.Xpf.NavBar.NavigationPanePanel.ArrangeOverride(Size finalSize)
at DevExpress.Xpf.Core.DXExpander.LayoutCalculator.ArrangeOverride(Size arrangeSize)
at DevExpress.Xpf.Core.DXExpander.ArrangeOverride(Size arrangeSize)
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
Inner Exception:
at DevExpress.Xpf.NavBar.NavPaneActiveGroupControl.MeasureOverride(Size constraint)
at DevExpress.Xpf.NavBar.NavigationPanePanel.MeasureOverride(Size availableSize)
at DevExpress.Xpf.Core.DXExpander.StretchLayoutCalculator.MeasureChild(UIElement child, Size constraint)
at DevExpress.Xpf.Core.DXExpander.LayoutCalculator.MeasureOverride(Size constraint)
at DevExpress.Xpf.Core.DXExpander.MeasureOverride(Size constraint)
at DevExpress.Xpf.NavBar.NavigationPaneView.MeasureOverride(Size availableSize)
at System.Windows.Controls.Decorator.MeasureOverride(Size constraint)
at DevExpress.Xpf.Core.DXArranger.MeasureOverride(Size constraint)
at DevExpress.Xpf.Docking.VisualElements.GroupPanel.MeasureOverride(Size constraint)
at System.Windows.Controls.ItemsPresenter.MeasureOverride(Size constraint)
at DevExpress.Xpf.Core.Native.DockPanelLayoutHelper.MeasureDockPanelLayout(FrameworkElement parent, Size constraint, SkipLayout skipLayout)
at DevExpress.Xpf.Core.Native.DockPanelLayoutHelper.MeasureDockPanelLayout(FrameworkElement parent, Size constraint)
at DevExpress.Xpf.Bars.BarManager.MeasureOverride(Size constraint)
at System.Windows.Documents.AdornerDecorator.MeasureOverride(Size constraint)
at DevExpress.Xpf.Core.DXWindow.MeasureOverrideHelper(Size constraint)
at DevExpress.Xpf.Core.DXWindow.MeasureOverride(Size availableSize)
at Infragistics.Windows.DataPresenter.AutoSizeFieldHelper.GetLabelPresenter(Field f, TemplateDataRecordCache cache)
at Infragistics.Windows.DataPresenter.AutoSizeFieldHelper.Calculate(RecordEnumeratorBase outOfViewRecords, AutoSizeCalculationFlags flags, RecordFieldList& recordFieldList, Boolean trackRecords, RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.AutoSizeFieldHelper.Calculate(RecordCollectionBase records, Int32 recordManagerDepth, AutoSizeCalculationFlags flags, RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.AutoSizeFieldLayoutInfo.PerformAutoSize(Boolean isHorz, IEnumerable`1 autoFields, RecordCollectionBase records, Int32 recordManagerDepth, HashSet recordsSubset, Boolean increaseOnly, OperationType operationType, FieldAutoSizeOptions allowedOptions, RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.AutoSizeFieldLayoutInfo.InitializeAutoSizedFieldsImpl(RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.AutoSizeFieldLayoutInfo.ProcessPendingOperationsImpl(RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.AutoSizeFieldLayoutInfo.ProcessPendingOperations(List`1 pendingAutoSize, RecordsInViewHelper recordsInViewHelper)
at Infragistics.Windows.DataPresenter.DataPresenterBase.ProcessPendingAutoSizeOperations()
at Infragistics.Windows.DataPresenter.DataPresenterBase.OnPerformFieldAutoSize(Object parameter)
Message: Exception has been thrown by the target of an invocation.
Inner Exception: System.NullReferenceException: Object reference not set to an instance of an object.
at Infragistics.Windows.DataPresenter.GridUtilities.ProcessAsyncInvalidationsImpl()
at Infragistics.Windows.DataPresenter.GridUtilities.ProcessAsyncInvalidations()
Source: mscorlib
Stack Trace: at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Delegate.DynamicInvokeImpl(Object[] args)
